BSM100N-1150BA
BSM100N-1150BA
BSM100N-1150BA TSTAT, RESOLVE
Company Baldor
Part Number bsm100n_1150ba
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 9.40 A
CUR CONT STALL/A RMS 9,47
Dimensional Drawing Numbers S4LYP101
Duty Rating CONT
Frame D165D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 4,000 rpm
Max Speed Rpm 4000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 9,47
Nameplate Output 2.43KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 34,1
Peak Current 34.1 A
Peak Torque 56.0 N-m
POWER 2.43KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 14 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,013
Shaft Diameter 1.103 in
Ship Weight 40 LB
SPEC. S4P101W053G1
Speed 2,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 14 NM
UPC 781568441428
