BSM100C-6250AA
BSM100C-6250AA
BSM100C-6250AA TSTAT RESOLVER
Company Baldor
Part Number bsm100c_6250aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 14.10 A
CUR CONT STALL/A RMS 14,1
Dimensional Drawing Numbers S4LYP124
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 14,1
Nameplate Output 3.84KW
Nameplate Speed 2400
Nameplate Voltage 600
Number of Poles 8
PEACK CUR/A RMS 35,9
Peak Current 35.9 A
Peak Torque 90.0 N-m
POWER 3.84KW
RATED BUS VOLTS 600
RATED SPEED/RPM 2400
Rated Torque 30 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) No
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 81 LB
SPEC. S4P124W117G1
Speed 2,400 rpm
TORQ CONT STALL 30 NM
UPC 781568535448
VOLTS No
