BSM100C-6150AA
BSM100C-6150AA
BSM100C-6150AA TSTAT, RES
Company Baldor
Part Number bsm100c_6150aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 24 A
CUR CONT STALL/A RMS 24,1
Dimensional Drawing Numbers S4LYP124
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 24,1
Nameplate Output 5.83KW
Nameplate Speed 4000
Nameplate Voltage 600
Number of Poles 8
PEACK CUR/A RMS 61,4
Peak Current 61.4 A
Peak Torque 90.0 N-m
POWER 5.83KW
RATED BUS VOLTS 600
RATED SPEED/RPM 4000
Rated Torque 30 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,08973
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 83 LB
SPEC. S4P124W116G1
Speed 4,000 rpm
TORQ CONT STALL 30 NM
UPC 781568388877
VOLTS No
