BSM100C-5250AA
BSM100C-5250AA
BSM100C-5250AA TSTAT RESOLVER
Company Baldor
Part Number bsm100c_5250aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 13 A
CUR CONT STALL/A RMS 13
Dimensional Drawing Numbers S4LYP124
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 13
Nameplate Output 4.9KW
Nameplate Speed 2400
Nameplate Voltage 600
Number of Poles 8
PEACK CUR/A RMS 33,1
Peak Current 33.1 A
Peak Torque 75.0 N-m
POWER 4.9KW
RATED BUS VOLTS 600
RATED SPEED/RPM 2400
Rated Torque 25 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,07478
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 72 LB
SPEC. S4P124W114G1
Speed 2,400 rpm
TORQ CONT STALL 25 NM
UPC 781568535431
VOLTS No
