BSM100C-5150AA
BSM100C-5150AA
BSM100C-5150AA TSTAT, RESOLVER
Company Baldor
Part Number bsm100c_5150aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 21 A
CUR CONT STALL/A RMS 21
Dimensional Drawing Numbers S4LYP124
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 21
Nameplate Output 5.64KW
Nameplate Speed 4000
Nameplate Voltage 600
Number of Poles 8
PEACK CUR/A RMS 53,7
Peak Current 53.7 A
Peak Torque 75.0 N-m
POWER 5.64KW
RATED BUS VOLTS 600
RATED SPEED/RPM 4000
Rated Torque 25 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,07478
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 84 LB
SPEC. S4P124W113G1
Speed 4,000 rpm
TORQ CONT STALL 25 NM
UPC 781568388860
VOLTS No
