BSM100C-4250AF
BSM100C-4250AF
BSM100C-4250AF TSTAT, ENCODER
Company Baldor
Part Number bsm100c_4250af
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 10.60 A
CUR CONT STALL/A RMS 10,6
Dimensional Drawing Numbers S4LYP158
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 10,6
Nameplate Output 2.71KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 26,9
Peak Current 26.9 A
Peak Torque 60.0 N-m
POWER 2.71KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 20 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,05982
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 60.5 LB
SPEC. S4P158W111
Speed 1,200 rpm
TORQ CONT STALL 20 NM
UPC 781568412718
VOLTS No
