BSM100C-3250AA
BSM100C-3250AA
BSM100C-3250AA TSTAT, RESOLVER
Company Baldor
Part Number bsm100c_3250aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 6.90 A
CUR CONT STALL/A RMS 6,96
Dimensional Drawing Numbers S4LYP124
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 6,96
Nameplate Output 2.07KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 17,8
Peak Current 17.8 A
Peak Torque 42.6 N-m
POWER 2.07KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 14.20 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,04487
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 65 LB
SPEC. S4P124W108
Speed 1,200 rpm
TORQ CONT STALL 14.2 NM
UPC 781568392133
VOLTS No
