BSM100C-3150AF
BSM100C-3150AF
BSM100C-3150AF TSTAT, ENCODER
Company Baldor
Part Number bsm100c_3150af
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 11.40 A
CUR CONT STALL/A RMS 11,4
Dimensional Drawing Numbers S4LYP158
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 11,4
Nameplate Output 3.33KW
Nameplate Speed 2400
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 29
Peak Current 29.0 A
Peak Torque 42.6 N-m
POWER 3.33KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2400
Rated Torque 14.20 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,04487
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 52 LB
SPEC. S4P158W107
Speed 2,400 rpm
TORQ CONT STALL 14.2 NM
UPC 781568412640
VOLTS No
