BSM100C-2150AA
BSM100C-2150AA
BSM100C-2150AA TSTAT, RESOLVER
Company Baldor
Part Number bsm100c_2150aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 8.02 A
CUR CONT STALL/A RMS 8,02
Dimensional Drawing Numbers S4LYP124
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 8,02
Nameplate Output 1.94KW
Nameplate Speed 2400
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 20,5
Peak Current 20.5 A
Peak Torque 30.0 N-m
POWER 1.94KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2400
Rated Torque 10 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,02991
RPM No
SER.F. No
Service Factor No
Shaft Diameter 1.103 in
Ship Weight 40.35 LB
SPEC. S4P124W104
Speed 2,400 rpm
TORQ CONT STALL 10 NM
UPC 781568387115
VOLTS No
