BSM100B-3250AA
BSM100B-3250AA
BSM100B-3250AA T-STATS RESOLVER
Company Baldor
Part Number bsm100b_3250aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
CUR CONT STALL/A RMS 8,23
Dimensional Drawing Numbers S4LYP100
Duty Rating CONT
Frame D165D
Frame Suffix D
Insulation Class F
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 12 AWG
Multiplier Symbol E4
Nameplate Amps 8,23
Nameplate Output 1.91KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 21
Peak Current 21.0 A
Peak Torque 51.0 N-m
POWER 1.91KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 17 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0584
Shaft Diameter 1.103 in
Ship Weight 76 LB
SPEC. S4P100W035
Speed 1,200 rpm
TORQ CONT STALL 17 NM
UPC 781568203897
