B1112N4004
B1112N4004
This size 11 brushless DC slotted mini motor is optimized for large bone drill applications; a cannulated shaft, motor torque and speed make this an ideal solution for powered surgical hand tools that are used for joint replacement surgeries of the knee, hip and shoulder. Portescap mini motors for surgical power applications are designed for high reliability in autoclave environments.
Designed for autoclave applications requiring up to 1000 autoclave cycles
Optimized for use in surgical powered devices
High torque for increased surgeon control and device power
Cannulated Gear-motor allows passage of pins through the motor for pin-driving, and wire-driving / K-wire applications
Lightweight and low vibration for increased surgeon tactile feel
High efficiency to optimize thermal performance at high speeds
Small size allowing smaller surgical hand tool designs and improved ergonomics
Withstands high current draw
Contact Portescap to see what customization options are available.
Part Number B1112N4004_sloted
Diameter, in 1.10
Length, in 3.60
Nominal Voltage, Volt 14.4
No-Load Speed, rpm 957
Back-EMF Constant, V/1000 rpm 0.94, 0.94
Torque Constant, oz-in/A 16.40
Mechanical Time Constant, ms 2.35
Electrical time constant, ms No
Weight Oz No
Motor Regulation R/k², 10³/Nms No
Max No-Load Current, mA 900
Continuous Stall Torque, oz-in 115.90
Continuous Stall Current, A 8.23
Peak Torque for 1s, oz-in No
Peak Current, A 95.7
Motor Constant, mNm/W½ 300.4
Inductance - phase to phase, mH 0.061
Thermal Resistance (winding to ambient), °C/W 8.3
Thermal Time Constant, s No
Rotor Inertia, oz-in-sec²10-6 120
Max winding temperature, °F No
Shaft Load Max Axial, lb No
Shaft Load Max Radial, lb No
Resistance per Phase, ± 10%, Ohms 0.15
Company Portescap
