B0614H4042
B0614H4042
This size 6 brushless DC slotted mini motor is optimized for arthroscopic shaver applications. Motor torque and speed make this an ideal solution for powered surgical hand tools that are used in minimally invasive surgical procedures to repair joints such as the hip, knee, and shoulder. Portescap mini motors for surgical power applications are designed for high reliability in autoclave environments.
Designed for autoclave applications requiring up to 1000 autoclave cycles
Optimized for use in surgical powered devices
High torque and high speed design optimized to remove soft tissue, hard tissue, or bone
High speed electric motors allow for cleaner soft tissue cuts and shorter surgery cases
Lightweight and low vibration for increased surgeon tactile feel
High efficiency for low temperature operation
Small size allowing smaller surgical hand tool designs and improved ergonomics
Withstands high current draw
Contact Portescap to see what customization options are available.
Part Number B0614H4042_sloted
Diameter, in 0.65
Length, in 2.88
Nominal Voltage, Volt 24.0, 24.0
No-Load Speed, rpm No
Back-EMF Constant, V/1000 rpm 5.64
Torque Constant, oz-in/A 6.86
Mechanical Time Constant, ms 2.43
Electrical time constant, ms 0.17
Weight Oz 3.80
Motor Regulation R/k², 10³/Nms 0.4
Max No-Load Current, mA 600
Continuous Stall Torque, oz-in 16.90
Continuous Stall Current, A 2.59
Peak Torque for 1s, oz-in 157.2
Peak Current, A 22.9
Motor Constant, mNm/W½ 47.8
Inductance - phase to phase, mH 0.180
Thermal Resistance (winding to ambient), °C/W 12.5
Thermal Time Constant, s 950
Rotor Inertia, oz-in-sec²10-6 17.80
Max winding temperature, °F No
Shaft Load Max Axial, lb 6.9
Shaft Load Max Radial, lb 14.2
Resistance per Phase, ± 10%, Ohms 1.03
Company Portescap
