AKM Washdown and Food Grade AKM4
Kollmorgen AKM™ Washdown and Washdown Food Series motors are available in frame sizes 2 through 6. These innovative motors incorporate our industry-leading AKM electromagnetics within a housing protected by a 2-K coating and IP67-rated seal configuration. Stainless steel hardware is used on all precision interfaces. The food-grade model incorporates greases that are safe for incidental contact and consumption.
Features
Frame sizes 2 through 6
Static torques from 1 to 25 N-m
Available with a wide range of standard lengths, windings, feedback systems and connection technologies
Resistant to corrosive chemicals including highly alkaline or acidic cleaning products
Food-grade version complies with FDA requirements, including lubricants and materials safe for incidental contact and consumption
IP67 seal design featuring PTFE shaft seal
Stainless steel shaft
Benefits
Ideal for applications subject to strict hygiene regulations
A cost-effective solution for any application that requires periodic washdown
Increased motor life
Higher purification rating
No additional cover or special protection required for the motor casing
Meets the needs of a wide range of applications without requiring expensive, high-grade stainless steel for the motor casing
Stainless steel used for motor shaft, screws and connectors
Part Number akm_washdown_and_food_grade_akm4
Stack Length No
Windings No
Max BUS (VDC) 640
Max Stall Tc Nm (lb-in) 6.0(53.1)
Max Tp Nm (lb-in) 20.4(181)
Max Rated N 6000
Max Rated Power @ Max BUS kW (Hp) 1.73(2.32)
Chemical Resistance (Ph) 2–12
Ingress Protection IP67
Shaft Stainless Steel
Connector Housing Stainless Steel
Company Kollmorgen
