AF-USR-40-1
AF-USR-40-1
Air Force One Cylinder
Company Clippard
Part Number AF-USR-40-1
Bore Size 2 1/2" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium No
Mount Universal Mount
Mounting Type Universal Mount
Ports 1/4 NPT
Power Factor No
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded 30 lb
String Force Retracted 15 lb
Stroke Length 1 Stroke
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed 25 lbs.
Spring Force at Rest 18.5 lbs.
