AF-UDD-12-1 1/2-V
AF-UDD-12-1 1/2-V
Universal Mount, D.A., Double Rod End, 3/4
Company Clippard
Part Number AF-UDD-12-1 1/2-V
Action Double Acting
Bore Size 3/4" Bore
Cylinder Type Double Rod
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Universal Mount
Mounting Type Universal Mount
Ports 10-32 Thread
Power Factor 0,44
Pressure Max 250 psi
Rod Double Rod
Rod Diameter 0,3125
Seal Material FKM
String Force Expanded 10 lb
String Force Retracted 4 lb
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
