AF-UDD-10-1
AF-UDD-10-1
Air Force One Cylinder
Company Clippard
Part Number AF-UDD-10-1
Action Double Acting
Bore Size 5/8" Bore
Cylinder Type Double Rod
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Universal Mount
Mounting Type Universal Mount
Ports 10-32 Thread
Power Factor 0,31
Pressure Max 250 psi
Rod Double Rod
Rod Diameter 0,25
Seal Material Nitrile
String Force Expanded 5.75 lb
String Force Retracted 1.5 lb
Stroke Length 1 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
