AF-TSR-10-1/2
AF-TSR-10-1/2
Air Force One Cylinder
Company Clippard
Part Number AF-TSR-10-1/2
Bore Size 5/8" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Treaded Mount
Mounting Type Threaded Mount
Ports 10-32 Thread
Power Factor 0,31
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,25
Seal Material Nitrile
String Force Expanded 5.75 lb
String Force Retracted 1.5 lb
Stroke Length No
Temperature Max 200 F
Spring Force Compressed 5.75 lbs.
Spring Force at Rest 1.5 lbs.
