AF-TRR-40-1/2-M
AF-TRR-40-1/2-M
Threaded Mount, Reverse Acting, Rotating Rod
Company Clippard
Part Number AF-TRR-40-1/2-M
Bore Size 2 1/2" Bore
Cylinder Type Reverse Acting
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Treaded Mount
Mounting Type Threaded Mount
Ports 1/4 NPT
Power Factor 4,9
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded 30 lb
String Force Retracted 15 lb
Stroke Length No
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed 25 lbs.
Spring Force at Rest 18.5 lbs.
