AF-TRR-24-1/2
AF-TRR-24-1/2
Air Force One Cylinder
Company Clippard
Part Number AF-TRR-24-1/2
Bore Size 1 1/2" Bore
Cylinder Type Reverse Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Treaded Mount
Mounting Type Threaded Mount
Ports 1/8 NPT
Power Factor 1,7
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,625
Rod Thread 3/8-24 Female Thread 0.500 Deep
Seal Material Nitrile
String Force Expanded 13 lb
String Force Retracted 7.5 lb
Stroke Length No
Temperature Max 200 F
Spring Force Compressed 13 lbs.
Spring Force at Rest 7.5 lbs.
