AF-TDR-17-1/4
AF-TDR-17-1/4
Air Force One Cylinder
Company Clippard
Part Number AF-TDR-17-1/4
Action Double Acting
Bore Size 1 1/16" Bore
Cylinder Type Double Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Treaded Mount
Mounting Type Threaded Mount
Ports 1/8 NPT
Power Factor 0,88
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,5
Rod Thread 5/16-24 Female Thread 0.500 Deep
Seal Material Nitrile
String Force Expanded No
String Force Retracted No
Stroke Length 1/4 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
