AF-TDD-40-1/2-M
AF-TDD-40-1/2-M
Threaded Mount, Double Acting, Double Rod
Company Clippard
Part Number AF-TDD-40-1/2-M
Action Double Acting
Bore Size 2 1/2" Bore
Cylinder Type Double Rod
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Treaded Mount
Mounting Type Threaded Mount
Ports 1/4 NPT
Power Factor 4,9
Pressure Max 250 psi
Rod Double Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded No
String Force Retracted No
Stroke Length No
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
