AF-TDD-12-1
AF-TDD-12-1
Air Force One Cylinder
Company Clippard
Part Number AF-TDD-12-1
Action Double Acting
Bore Size 3/4" Bore
Cylinder Type Double Rod
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Treaded Mount
Mounting Type Threaded Mount
Ports 10-32 Thread
Power Factor 0,44
Pressure Max 250 psi
Rod Double Rod
Rod Diameter 0,3125
Seal Material Nitrile
String Force Expanded 10 lb
String Force Retracted 4 lb
Stroke Length 1 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
