AF-RSR-40-1 1/2-M
AF-RSR-40-1 1/2-M
Rear Mount, Single Acting, Rotating Rod
Company Clippard
Part Number AF-RSR-40-1 1/2-M
Bore Size 2 1/2" Bore
Cylinder Type Single Acting
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Rear Mount
Mounting Type Rear Mount
Ports 1/4 NPT
Power Factor 4,9
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded 30 lb
String Force Retracted 15 lb
Stroke Length 1 1/2 Stroke
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed 25 lbs.
Spring Force at Rest 18.5 lbs.
