AF-RSR-17-1 1/2-M
AF-RSR-17-1 1/2-M
Rear Mount, Single Acting, Rotating Rod
Company Clippard
Part Number AF-RSR-17-1 1/2-M
Bore Size 1 1/16" Bore
Cylinder Type Single Acting
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Rear Mount
Mounting Type Rear Mount
Ports 1/8 NPT
Power Factor 0,88
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,5
Rod Thread 5/16-24 Female Thread 0.500 Deep
Seal Material Nitrile
String Force Expanded 11.5 lb
String Force Retracted 5.5 lb
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed 11.5 lbs.
Spring Force at Rest 5.5 lbs.
