AF-RSR-12-1 1/2
AF-RSR-12-1 1/2
Air Force One Cylinder
Company Clippard
Part Number AF-RSR-12-1 1/2
Bore Size 3/4" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Rear Mount
Mounting Type Rear Mount
Ports 10-32 Thread
Power Factor 0,44
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,3125
Seal Material Nitrile
String Force Expanded 10 lb
String Force Retracted 4 lb
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed 10 lbs.
Spring Force at Rest 4 lbs.
