AF-RDR-32-1-V
AF-RDR-32-1-V
Rear Mount, D.A., 2 Bore
Company Clippard
Part Number AF-RDR-32-1-V
Action Double Acting
Bore Size 2" Bore
Cylinder Type Double Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Rear Mount
Mounting Type Rear Mount
Ports 1/8 NPT
Power Factor 3,1
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material FKM
String Force Expanded No
String Force Retracted No
Stroke Length 1 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
