AF-RDR-10-2-V
AF-RDR-10-2-V
Rear Mount, D.A., 5/8
Company Clippard
Part Number AF-RDR-10-2-V
Action Double Acting
Bore Size 5/8" Bore
Cylinder Type Double Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium No
Mount Rear Mount
Mounting Type Rear Mount
Ports 10-32 Thread
Power Factor No
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,25
Seal Material FKM
String Force Expanded 5.75 lb
String Force Retracted 1.5 lb
Stroke Length 2 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
