AF-RDR-10-1/2-V
AF-RDR-10-1/2-V
Rear Mount, D.A., 5/8 Bore
Company Clippard
Part Number AF-RDR-10-1/2-V
Action Double Acting
Bore Size 5/8" Bore
Cylinder Type Double Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Rear Mount
Mounting Type Rear Mount
Ports 10-32 Thread
Power Factor 0,31
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,25
Seal Material FKM
String Force Expanded 5.75 lb
String Force Retracted 1.5 lb
Stroke Length No
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
