AF-FSR-32-1
AF-FSR-32-1
Air Force One Cylinder
Company Clippard
Part Number AF-FSR-32-1
Bore Size 2" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 1/8 NPT
Power Factor 3,1
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded 13 lb
String Force Retracted 7.5 lb
Stroke Length 1 Stroke
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed 13 lbs.
Spring Force at Rest 7.5 lbs.
