AF-FSR-32-1/2-M
AF-FSR-32-1/2-M
Front Mount, Single Acting, Rotating Rod
Company Clippard
Part Number AF-FSR-32-1/2-M
Bore Size 2" Bore
Cylinder Type Single Acting
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 1/8 NPT
Power Factor 3,1
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded 13 lb
String Force Retracted 7.5 lb
Stroke Length No
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed 13 lbs.
Spring Force at Rest 7.5 lbs.
