AF-FSR-12-1/4
AF-FSR-12-1/4
Air Force One Cylinder
Company Clippard
Part Number AF-FSR-12-1/4
Bore Size 3/4" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium No
Mount Front Mount
Mounting Type Front Mount
Ports 10-32 Thread
Power Factor No
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,3125
Seal Material Nitrile
String Force Expanded 10 lb
String Force Retracted 4 lb
Stroke Length 1/4 Stroke
Temperature Max 200 F
Spring Force Compressed 10 lbs.
Spring Force at Rest 4 lbs.
