AF-FSR-12-1 1/2-V
AF-FSR-12-1 1/2-V
Front Mount, S.A., 3/4 Bore
Company Clippard
Part Number AF-FSR-12-1 1/2-V
Bore Size 3/4" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 10-32 Thread
Power Factor 0,44
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,3125
Seal Material FKM
String Force Expanded 10 lb
String Force Retracted 4 lb
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed 10 lbs.
Spring Force at Rest 4 lbs.
