AF-FSR-10-1 1/2-V
AF-FSR-10-1 1/2-V
Front Mount, S.A., 5/8 Bore
Company Clippard
Part Number AF-FSR-10-1 1/2-V
Bore Size 5/8" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 10-32 Thread
Power Factor 0,31
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,25
Seal Material FKM
String Force Expanded 5.75 lb
String Force Retracted 1.5 lb
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed 5.75 lbs.
Spring Force at Rest 1.5 lbs.
