AF-FDR-40-1 1/2-V
AF-FDR-40-1 1/2-V
Front Mount, D.A., 2 1/2 Bore
Company Clippard
Part Number AF-FDR-40-1 1/2-V
Action Double Acting
Bore Size 2 1/2" Bore
Cylinder Type Double Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 1/4 NPT
Power Factor 4,9
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material FKM
String Force Expanded No
String Force Retracted No
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
