AF-FDR-40-1 1/2-M
AF-FDR-40-1 1/2-M
Front Mount, Double Acting, Rotating Rod
Company Clippard
Part Number AF-FDR-40-1 1/2-M
Action Double Acting
Bore Size 2 1/2" Bore
Cylinder Type Double Acting
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 1/4 NPT
Power Factor 4,9
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded No
String Force Retracted No
Stroke Length 1 1/2 Stroke
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
