AF-FDD-24-1 1/2-M
AF-FDD-24-1 1/2-M
Front Mount, Double Acting, Double Rod
Company Clippard
Part Number AF-FDD-24-1 1/2-M
Action Double Acting
Bore Size 1 1/2" Bore
Cylinder Type Double Rod
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Front Mount
Mounting Type Front Mount
Ports 1/8 NPT
Power Factor 1,7
Pressure Max 250 psi
Rod Double Rod
Rod Diameter 0,625
Rod Thread 3/8-24 Female Thread 0.500 Deep
Seal Material Nitrile
String Force Expanded No
String Force Retracted No
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
