AF-BSR-40-1-V
AF-BSR-40-1-V
Bottom Mount, S.A., 2 1/2 Bore
Company Clippard
Part Number AF-BSR-40-1-V
Bore Size 2 1/2" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Bottom Mount
Mounting Type Bottom Mount
Ports 1/4 NPT
Power Factor 4,9
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material FKM
String Force Expanded 30 lb
String Force Retracted 15 lb
Stroke Length 1 Stroke
Temperature Max 200 F
Spring Force Compressed 25 lbs.
Spring Force at Rest 18.5 lbs.
