AF-BSR-32-1 1/2-V
AF-BSR-32-1 1/2-V
Bottom Mount, S.A., 2 Bore
Company Clippard
Part Number AF-BSR-32-1 1/2-V
Bore Size 2" Bore
Cylinder Type Single Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Bottom Mount
Mounting Type Bottom Mount
Ports 1/8 NPT
Power Factor 3,1
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material FKM
String Force Expanded 13 lb
String Force Retracted 7.5 lb
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed 13 lbs.
Spring Force at Rest 7.5 lbs.
