AF-BRR-10-1
AF-BRR-10-1
Air Force One Cylinder
Company Clippard
Part Number AF-BRR-10-1
Bore Size 5/8" Bore
Cylinder Type Reverse Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Bottom Mount
Mounting Type Bottom Mount
Ports 10-32 Thread
Power Factor 0,31
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,25
Seal Material Nitrile
String Force Expanded 5.75 lb
String Force Retracted 1.5 lb
Stroke Length 1 Stroke
Temperature Max 200 F
Spring Force Compressed 5.75 lbs.
Spring Force at Rest 1.5 lbs.
