AF-BDR-32-1 1/2-M
AF-BDR-32-1 1/2-M
Block Mount, Double Acting, Rotating Rod
Company Clippard
Part Number AF-BDR-32-1 1/2-M
Action Double Acting
Bore Size 2" Bore
Cylinder Type Double Acting
Magnet Option Magnet
Max PSI 250 PSI
Medium Air
Mount Bottom Mount
Mounting Type Bottom Mount
Ports 1/8 NPT
Power Factor 3,1
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,75
Seal Material Nitrile
String Force Expanded No
String Force Retracted No
Stroke Length 1 1/2 Stroke
Temperature Range 30 F to 250 F
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
