AF-BDR-24-1 1/2-V
AF-BDR-24-1 1/2-V
Bottom Mount, D.A., 1 1/2 Bore
Company Clippard
Part Number AF-BDR-24-1 1/2-V
Action Double Acting
Bore Size 1 1/2" Bore
Cylinder Type Double Acting
Magnet Option No Magnet
Max PSI 250 PSI
Medium Air
Mount Bottom Mount
Mounting Type Bottom Mount
Ports 1/8 NPT
Power Factor 1,7
Pressure Max 250 psi
Rod Rotating Rod
Rod Diameter 0,625
Rod Thread 3/8-24 Female Thread 0.500 Deep
Seal Material FKM
String Force Expanded No
String Force Retracted No
Stroke Length 1 1/2 Stroke
Temperature Max 200 F
Spring Force Compressed No
Spring Force at Rest No
