ADM1220S-V12-36+12/3 20.6:1+MG09
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 12V coil with sleeve bearings. with FAULHABER® series 12/3, 12 mm dia. precision spur gearhead, 20.6:1 reduction ratio and 2.0 mm dia. output shaft.
Part Number adm1220s_v12_36_12_3_20_6_1_mg
Axial Shaft Load Max 2 N
Back EMF Constant Rotary 10 mV/rpm
Company MicroMo
Continuous Torque, Max. 8 mNm
Direction Of Rotation CW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. 15000 rpm
Gearhead Ratio 20.6:1
Gearhead Series 12/3
Intermittent Torque, Max. 100 mNm
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 12V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 12 mm
Overall Length 34.8 mm
Overall Weight 0.042 lbs
Radial Shaft Load, Max. 3 N
Recommended Input Speed, Max. 5000 rpm
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 60 V
Terminal Inductance 57000 μH
Terminal/Phase Resistance 164 Ω
Torque Constant Rotary 4.1 mNm/A
