ADM1220S-2R-V3-36+12/3 235:1+MG09
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 3.0V coil with two ball bearings. with FAULHABER® series 12/3, 12 mm dia. precision spur gearhead, 235:1 reduction ratio and 2.0 mm dia. output shaft.
Part Number adm1220s_2r_v3_36_12_3_235_1_m
Axial Shaft Load Max 2 N
Back EMF Constant Rotary 2.6 mV/rpm
Company MicroMo
Continuous Torque, Max. 30 mNm
Direction Of Rotation CCW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. 15000 rpm
Gearhead Ratio 235:1
Gearhead Series 12/3
Intermittent Torque, Max. 100 mNm
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 3V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 12 mm
Overall Length 41.2 mm
Overall Weight 0.049 lbs
Radial Shaft Load, Max. 3 N
Recommended Input Speed, Max. 5000 rpm
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 15 V
Terminal Inductance 3500 μH
Terminal/Phase Resistance 13 Ω
Torque Constant Rotary 4.1 mNm/A
