ADM1220S-2R-V3-34+10/1 256:1+MG09
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 3.0V coil with two ball bearings. with FAULHABER® series 10/1, 10 mm dia. precision planetary gearhead, 256:1 reduction ratio and 2.0 mm dia. output shaft.
Part Number adm1220s_2r_v3_34_10_1_256_1_m
Axial Shaft Load Max 2 N
Back EMF Constant Rotary 2.6 mV/rpm
Company MicroMo
Continuous Torque, Max. 100 mNm
Direction Of Rotation CW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. 15000 rpm
Gearhead Ratio 256:1
Gearhead Series 10/1
Intermittent Torque, Max. 200 mNm
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 3V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 12 mm
Overall Length 36.3 mm
Overall Weight 0.042 lbs
Radial Shaft Load, Max. 1 N
Recommended Input Speed, Max. 5000 rpm
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 15 V
Terminal Inductance 3500 μH
Terminal/Phase Resistance 13 Ω
Torque Constant Rotary 4.1 mNm/A
