ADM1220S-2R-V3-30
ADM1220S-2R-V3-30
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 3.0V coil with two ball bearings. and plain shaft for M3 lead screw.
Part Number adm1220s_2r_v3_30
Axial Shaft Load Max No
Back EMF Constant Rotary 2.6 mV/rpm
Company MicroMo
Continuous Torque, Max. No
Direction Of Rotation No
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. No
Gearhead Ratio No
Gearhead Series No
Intermittent Torque, Max. No
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 3V
Operating Temp, Max. No
Operating Temp, Min. No
Overall Diameter 12 mm
Overall Length 17.4 mm
Overall Weight 0.020 lbs
Radial Shaft Load, Max. No
Recommended Input Speed, Max. No
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 15 V
Terminal Inductance 3500 μH
Terminal/Phase Resistance 13 Ω
Torque Constant Rotary 4.1 mNm/A
