ADM1220S-2R-V2-36+12/5 2050:1+MG0125
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 2.0V coil with two ball bearings. with FAULHABER® series 12/5, 12 mm dia. precision zero-backlash spur gearhead, 2050:1 reduction ratio and 2.0 mm dia. output shaft.
Part Number adm1220s_2r_v2_36_12_5_2050_1
Axial Shaft Load Max 5 N
Back EMF Constant Rotary 1.7 mV/rpm
Company MicroMo
Continuous Torque, Max. 30 mNm
Direction Of Rotation CCW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. 15000 rpm
Gearhead Ratio 2050:1
Gearhead Series 12/5
Intermittent Torque, Max. 100 mNm
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 2V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 12 mm
Overall Length 44.5 mm
Overall Weight 0.053 lbs
Radial Shaft Load, Max. 5 N
Recommended Input Speed, Max. 5000 rpm
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 10 V
Terminal Inductance 1300 μH
Terminal/Phase Resistance 5.4 Ω
Torque Constant Rotary 4.1 mNm/A
