ADM1220S-2R-V2-34+10/1 1024:1+MG09
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 2.0V coil with two ball bearings. with FAULHABER® series 10/1, 10 mm dia. precision planetary gearhead, 1024:1 reduction ratio and 2.0 mm dia. output shaft.
Part Number adm1220s_2r_v2_34_10_1_1024_1
Axial Shaft Load Max 2 N
Back EMF Constant Rotary 1.7 mV/rpm
Company MicroMo
Continuous Torque, Max. 100 mNm
Direction Of Rotation CW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. 15000 rpm
Gearhead Ratio 1024:1
Gearhead Series 10/1
Intermittent Torque, Max. 200 mNm
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 2V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 12 mm
Overall Length 39.5 mm
Overall Weight 0.044 lbs
Radial Shaft Load, Max. 1 N
Recommended Input Speed, Max. 5000 rpm
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 10 V
Terminal Inductance 1300 μH
Terminal/Phase Resistance 5.4 Ω
Torque Constant Rotary 4.1 mNm/A
