ADM1220S-2R-V12-38+12/4 16:1+MG09
FAULHABER® PRECIstep® Technology series ADM1220S, 12 mm dia. 2 phase disc magnet DC stepper motor with low residual torque, 12V coil with two ball bearings. with FAULHABER® series 12/4, 12 mm dia. precision planetary gearhead, 16:1 reduction ratio and 3.0 mm dia. output shaft.
Part Number adm1220s_2r_v12_38_12_4_16_1_m
Axial Shaft Load Max 3 N
Back EMF Constant Rotary 10 mV/rpm
Company MicroMo
Continuous Torque, Max. 300 mNm
Direction Of Rotation CW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.2 mNm
Gearhead Intermittent Input Speed, Max. 15000 rpm
Gearhead Ratio 16:1
Gearhead Series 12/4
Intermittent Torque, Max. 450 mNm
Lead Time 20 Business Days
Motor Series ADM1220S
Motor Winding Description 12V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 12 mm
Overall Length 37.0 mm
Overall Weight 0.053 lbs
Radial Shaft Load, Max. 4 N
Recommended Input Speed, Max. 5000 rpm
Rotor Inertia 0.2 gcm2
Stepper Drive Voltage, Min. 60 V
Terminal Inductance 57000 μH
Terminal/Phase Resistance 164 Ω
Torque Constant Rotary 4.1 mNm/A
