A2 Absolute Optical Shaft Encoder
The A2 optical encoder is a 12 bit absolute rotary position sensor which reports a shaft angle within a single 360 degree rotation of a shaft. Unlike incremental, sometimes called relative, style encoders the A2 provides true (absolute) shaft position eliminating the need for a home or zero cycle after a supply voltage power cycle. The A2 communicates over a RS 485 style serial bus utilizing US Digital`s SEI (Serial Encoder Interface) which allows for simple, quick and convenient networking of multiple SEI devices on a single network. PLCs, motion controllers and computers can also reside on the SEI bus as well by use of US Digital`s SEI to USB interface device. For complete information about the SEI bus please refer to the SEI Communications Protocol webpage.The A2 is also available with an optional analog output. The analog output option provides a maximum voltage range of 0 to 4.095 volts with 12 bit resolution. The output voltage may be easily scaled by simple SEI commands to provide other maximum voltage levels as well. From the factory the analog output voltage is set to 0 to 3.599 VDC range. Please note that with the A2 analog output option only one device may reside on a SEI bus. Sleeve bushing or ball bearing versions 12-bit resolution and resolution field programmable from 2 to 4,096 codes per revolution (3,600 factory default) Full 360 degrees range, 7 msec update time Low power drain of 18.5 mA max., and 1.5 mA in sleep mode Field programmable parameters such as setting zero position point (demo software available for download below) EEPROM stores downloadable parameters 9,600 baud default data rate adjustable up to 115K baud 12-bit analog voltage output option (0 to +3.599 volts factory default setting. Field programmable up to 0 to +4.095 volts) Multi-turn mode (note: power must be maintained to prevent reset to zero) -25 to 70 degrees C. operating temperature
Part Number a2_absolute_optical_sha
Company US Digital
Electrostatic Discharge, Human Body ModelMIL-STD-883E, Method 3015.7 No
Electrostatic Discharge, IEC 61000-4-2 ± 4 kV
Humidity, Non-condensing 0 to 95 %
Storage Temperature No
Vibration (5Hz to 2kHz), G 20
Operating Temperature, C -25 to 70
