7SD-2
7SD-2
7/8 Heavy Duty, Double Acting, Stud Mount Cylinder, 2
Company Clippard
Part Number 7SD-2
Action Double Acting
Max PSI Air:250 PSI Hyd:2000 PSI
Medium Air & Hydraulic
Mount Stud Mount
Ports 1/8 NPT
Power Factor 0,6
Rod Rotating Rod
Rod Diameter 0,25
Stroke C 2
Spring Force Extended No
Spring Force Retracted No
